HomeHomeCalendarFAQSearchMemberlistRegisterLog in
Click here to visit our sponsors
 What is the best airbox for the R53 and why?
Goto page : 1, 2, 3, 4  Next
Male Posts: 2612
PostSubject: What is the best airbox for the R53 and why?   12th March 2010, 12:13
1) Stock with ITG
2) JCW deflapped
3) GTT cold ram
4) Dave F
5) Other
Call it like you see it but back up your claim Wink
View user profile
ollieworks
Male Posts: 565
PostSubject: Re: What is the best airbox for the R53 and why?   12th March 2010, 12:38
well mine came with the JCW which i deflapped, but im currently using the GTT and i feel its better than the JCW
View user profile
Admin
Admin
Male Posts: 5688
PostSubject: Re: What is the best airbox for the R53 and why?   12th March 2010, 12:41
Dave.f
Keeps the airbox looking the same as stock, puts a circular filter in and has one of the larger pipes into the scuttles. Its a cheaper, improvement in the JCW box. All the others (stock, GTT) leak hot air so reduce performance.
View user profile http://surreynewmini.forumotion.com
Male Posts: 2612
PostSubject: Re: What is the best airbox for the R53 and why?   12th March 2010, 13:00
I am watching a GTT on ebay - how much is the Dave.f?
View user profile
ollieworks
Male Posts: 565
PostSubject: Re: What is the best airbox for the R53 and why?   12th March 2010, 13:14
£130 ish i think, but the guy only makes a few every now and again so can be difficult to get hold of i think
View user profile
Male Posts: 2612
PostSubject: Re: What is the best airbox for the R53 and why?   12th March 2010, 13:23
Might just on the GTT if it stays low then - how do you find it? Did you cut a hole in back panel or remove it completely?
View user profile
ollieworks
Male Posts: 565
PostSubject: Re: What is the best airbox for the R53 and why?   12th March 2010, 14:16
if find it good actually it sits well in place and makes a good seal against the bonnet to stop the hot air
View user profile
Admin
Admin
Male Posts: 5688
PostSubject: Re: What is the best airbox for the R53 and why?   12th March 2010, 14:34
Thats the bit I didn't like, it relys on the bonnet to make the air-lock, and there is no proof it can actually do this as the bonnet has to be closed for you to check!
Female Posts: 9575
PostSubject: Re: What is the best airbox for the R53 and why?   12th March 2010, 14:35
I had a k&n that Caz has now & now have a gtt cold ram & really happy with, make my miltek sounds fat & keeps cool on long journys.
Just remeber especially on the r53 to get one with a cover/guard around the cone to keep the cool air coming otherwise you will have probs if the enguine heat gets near it as i found out.
View user profile
Male Posts: 2612
PostSubject: Re: What is the best airbox for the R53 and why?   12th March 2010, 14:39
It is easy to test the seal - you put vaseline all round the top rubber of the heat shield, close the bonnet for two seconds, then open it - hey presto you either have a square of vaseline on the bonnet or you don't. Smile
But I agree it's a potential weakness - prob why Alta now do a lid on theirs!
View user profile
Admin
Admin
Male Posts: 5688
PostSubject: Re: What is the best airbox for the R53 and why?   12th March 2010, 14:42
And isn't the surround a thin bit of plastic? Bad heat gain through those, as opposed to the 6mm thick JCW/Std/Dave.f
To be honest, I would go down either:
De-flapped JCW
or
Dave.f
Both are the best your going to get for the airbox, both tried and tested. Not sure how much the JCW is though as an upgrade.
Male Posts: 2612
PostSubject: Re: What is the best airbox for the R53 and why?   12th March 2010, 14:47
Well this is manufacturers claim on heat:
"The 5mm air gap between the skins gives a superb thermal barrier. After a hard run the Ram Pipe remains ice cold to the touch. The upper airbox/heatshield is anodised in an attractive blue finish for good appearance and longevity."
So who knows?
How long is wait list for a Dave.f and how do I contcat him?
View user profile
Admin
Admin
Male Posts: 5688
PostSubject: Re: What is the best airbox for the R53 and why?   12th March 2010, 14:53
You need to sign up on mini Torque for the dave.f. April will be his next batch Smile
ollieworks
Male Posts: 565
PostSubject: Re: What is the best airbox for the R53 and why?   12th March 2010, 15:12
De-flapped JCW
or
Dave.f
i did check and it does make a good seal, its a thick rubber strip that runs around the top so it can be squashed down, and its blue and blue things please me Razz
View user profile
Male Posts: 2612
PostSubject: Re: What is the best airbox for the R53 and why?   12th March 2010, 15:26
Well the GTT is currently at £50, which is worth a punt over £130 and a wait for the dave.f. If it goes up above £75 I will lose interest lol
View user profile
Page 1 of 4Goto page : 1, 2, 3, 4  Next
Surrey New MINI :: Bits & Bobs :: General Discussion-
