 Front Speaker size and upgrades
frankie_C
PostSubject: Front Speaker size and upgrades   26th September 2010, 17:20
Hi Guys!
Long time no see!
i have been busy upgrading my audio set up and have fitted an EDGE 10" sub in the boot. i am looking at upgrading the rest with the same products but i am unsure about the front speakers. Could anyone please tell me what the original size speakers are in the front doors of my 2005 cooper cabriolet and what sizes fit straight in?
PostSubject: Re: Front Speaker size and upgrades   26th September 2010, 20:18
Hi stranger Smile
I'm sure I read they are 6" Very Happy
mikeythemini
PostSubject: Re: Front Speaker size and upgrades   27th September 2010, 17:28
You can fit 13cm or 16,5cm
Both will need a spacer ring which you can buy ready to fit with original screws or you can make up rings from MDF
http://www.newministuff.com
frankie_C
PostSubject: Re: Front Speaker size and upgrades   30th September 2010, 21:18
thanks guys wait till you hear my set up i am fitting it on saturday
frankie_C
PostSubject: Re: Front Speaker size and upgrades   4th October 2010, 20:56
heys guys!
my system is now in but i am having trouble with the amp it keeps going into protection mode after 10-20 seconds of playing music and it cuts all sound off.
i have an edge ED7400 if you have any recommendations all would be helpful
thanks again!
PostSubject: Re: Front Speaker size and upgrades   7th October 2010, 11:06
How easy was it to wire up! did you take the wires down the passenger door pannels or under the carpet?
frankie_C
PostSubject: Re: Front Speaker size and upgrades   7th October 2010, 22:05
i have now wired both sub and amp all power cables go down left hand side of gearbox tunnel as the access to the battery is in the n/s footwell behind the glove box. all audio cables are down the right hand side of gear box tunnel as they cause interference. speaker wiring runs down sills into the boot. all wiring runs under the carpet but make sure you do not damage any when you put the car back together you really need to tuck it down the side of the gearbox tunnel there is alot of polystyrene packers and thick parts of backing on the carpet some bits are tricky.
