 Why is my paint cracking
PostSubject: Why is my paint cracking   24th May 2012, 19:34
I re sprayed my mirror caps today
when i left they to dry they were perfect!
when i came back to them the paint had like cracked?
whats happened?
Thanks Smile x
PostSubject: Re: Why is my paint cracking   24th May 2012, 20:07
Did you prep them before you sprayed them? Smile
PostSubject: Re: Why is my paint cracking   24th May 2012, 20:20
If you primed them and painted them the same day. This is why,the paint under the top coat will crack,did you put them in the sun.??.or the paint has had a reaction to the primer.you will have torub down and start again.and this this give the primer a day to dry,than you should be fine,
PostSubject: Re: Why is my paint cracking   24th May 2012, 20:41
The primer seemed dry. And there was no cracks on the primer? The paint only cracked after the gloss was put on :s
PostSubject: Re: Why is my paint cracking   24th May 2012, 20:44
Did you put them in the sun?
When you say gloss do you mean lacquer
Matt93
PostSubject: Re: Why is my paint cracking   24th May 2012, 21:52
Too hot, in sunlight? or paint reacted with primer...primer wet?
Where was the paint from?
PostSubject: Re: Why is my paint cracking   24th May 2012, 22:42
The paint is the same make as the primer? So surly that wouldn't react?
The laquer is a different brand. It only cracked when that was drying?
PostSubject: Re: Why is my paint cracking   24th May 2012, 22:44
The lacquer may not be compatible with the paint (?) and you might need to try all three from the same brand.
PostSubject: Re: Why is my paint cracking   24th May 2012, 23:15
Or you over done the lacquer I have done this before where I put to much on and it's cracked,thing coat is best when using lacquer.
simone16
PostSubject: Re: Why is my paint cracking   28th January 2014, 11:59
could have reacted?
