 what is the difference between bi xenon headlights and not
miffy
PostSubject: what is the difference between bi xenon headlights and not   30th September 2012, 20:11
What is the difference ?I know they look abit different...
Solarin
PostSubject: Re: what is the difference between bi xenon headlights and not   30th September 2012, 20:22
Xenons are usually brighter than normal headlights (they often appear to have a blueish hue at night compared to other headlights). Usually they are pretty recognisable on cars!
The Bi-Xenons are also self levelling (a legal requirement for xenons as they are so bright) so you don't need to adjust the hight yourself.
miffy
PostSubject: Re: what is the difference between bi xenon headlights and not   30th September 2012, 20:34
Thank you..I am totally ignorant when it comes to techie stuff so will prob be asking lots of questions.. Embarassed
PostSubject: Re: what is the difference between bi xenon headlights and not   30th September 2012, 20:56
Xenon bulbs use gas which electricity passes through to create light, and normal xenon headlight units usually have a normal halogen bulb for the main/full beam - this means you have 2 bulbs in them, a xenon for your dipped beam and a halogen for your main/full beam.
The difference with bi-xenon headlights is that they only have a xenon bulb which is used for both dipped and main/full beam. If you listen carefully, when you flash the headlights, you'll hear a kind of clunking noise - this is where a screen, which usually sits in the path of the light beam, is moved within the headlight unit to allow more light out basically, therefore giving you your full/main beam.
Hopefully that makes sense! Smile
PostSubject: Re: what is the difference between bi xenon headlights and not   30th September 2012, 20:58
Most xenon-equipped headlights are only offered as a low-beam headlight with a halogen bulb for the high beam. Bi-xenon headlights offer xenon-light output for the low and high beams, and they’re housed in the same headlight projector Smile
Bi-xenon headlights typically have a shade or filter in front of the bulb during low-beam operation. When the high-beams are needed, the shade moves out of the way and the bulb’s full-light output is projected onto the road.
Very Happy
miffy
PostSubject: Re: what is the difference between bi xenon headlights and not   30th September 2012, 21:11
They sound like something out of a science fiction movie...WICKED.....coupes have them... Very Happy
PostSubject: Re: what is the difference between bi xenon headlights and not   30th September 2012, 21:15
Haha yep they come standard as part of the Chili pack on the S/JCW, or an option on the other models - 1st gen's only had the standard xenons, the bi-xenons came in with the 2nd gen Very Happy
PostSubject: Re: what is the difference between bi xenon headlights and not   30th September 2012, 21:17
Miff, I also have adaptive lights Wink
miffy
PostSubject: Re: what is the difference between bi xenon headlights and not   30th September 2012, 21:27
thats cause you is posh..... Very Happy
PostSubject: Re: what is the difference between bi xenon headlights and not   30th September 2012, 21:29
I is and reside in Surrey and need to see round corners lol!
PostSubject: Re: what is the difference between bi xenon headlights and not   30th September 2012, 21:35
The easy way to put it is:
normal headlights on minis: you can't see well and end up in a ditch unless theres street lighting or you eat a lot of carrots
xenons: Work well, better than halogens - spot lights are a benefit
bi-xenons: you can't tell the difference between night and day
miffy
PostSubject: Re: what is the difference between bi xenon headlights and not   30th September 2012, 21:41
WOW...they sound wicked...and Dave we do have corners in Warwickshire, lots of em....
