 Oil Check R56
PostSubject: Oil Check R56   12th May 2013, 23:48
Hi Everyone,
So on my way home this evening i went round a roundabout quite enthusiastically and heard a 'Bong' and it showed my Oil light. When i straightened up this picture went away.
Since i have got home i have had a look and apparently its a Oil Pressure Symbol and you should stop straight away. I then left the car for a bit of time and then went and checked the oil.
Now first thing is. Does anyone else have trouble reading the dipstick on the R56? Its horrible.
And secondly, if there is and issue, would the oil light stay on?
Harry
wlondoner
Member Number - SnM : 36
PostSubject: Re: Oil Check R56   13th May 2013, 00:07
My previous R56 did the same when it was low on oil if I went round a corner quickly it would show up on the dash for a second then go away and not stay on.
Top it up ASAP! Smile
CTurbinado
i agree... the dipstick design is terrible...
PostSubject: Re: Oil Check R56   13th May 2013, 00:10
This is what i was thinking but if its an oil pressure light, would it show up if your low? Plus when i look at the dipstick its so hard to read, i dont want to over fill it aha
Its awful!!
wlondoner
PostSubject: Re: Oil Check R56   13th May 2013, 00:46
I would put in half a small bottle if you cant read the dipstick and then go round a corner quick again see if it comes on again lol
PostSubject: Re: Oil Check R56   13th May 2013, 06:49
Most certainly low oil....
Top up as you could do massive damage!
Stefano
PostSubject: Re: Oil Check R56   13th May 2013, 08:31
agree with all previous posts....these things chew up oil and bmw saying you need to check monthly at the very least....cite low oil as key reason for chain tensioner issues (clearly not their fault!!!!).....TM did a group buy on a craven dip stck last year - its expensive but much better design so worth it imo given how important the oil thing is....
PostSubject: Re: Oil Check R56   13th May 2013, 11:43
Yes, I got the low pressure warninig on a number of righthanders & roundabouts, and the dipstick is atrocious.
Have you topped it up since you had it? You should be due a top up by now? I'm surprised if your dealer didnt warn you monthly/1000 mile top ups are the norm? Mine did and gave me a bottle of oil when I picked my clubbie up.
PostSubject: Re: Oil Check R56   13th May 2013, 12:35
I was warned as well........
Saying that in over 18mths only put about 1/4 of a litre in.......
PostSubject: Re: Oil Check R56   13th May 2013, 13:14
No. The dealer never said anything. And haven't topped up yet. Checked my oil 2 weeks ago and it seemed fine. Checked it this morning and again, it looks fine. Don't know if its all related to the issue I am allready having. Will top it up and see if I have a change. Don't want to over fill.
The car is going into mini on the 20th so I will mention it aswell
PostSubject: Re: Oil Check R56   13th May 2013, 19:56
Right. Oil crisis averted.
I'm not quite sure what to put this down to. Think its going to have to be human error. I checked it two odd weeks ago and was sure it looked fine. But looking at it today, i dont see how it could have used that much oil.
Looked at it after work after the car had been left all day so was cold. Was barely on the dipstick. Luckily i had been to halfords at lunch and picked up some oil. It took nearly 2L. I couldn't believe it.
Think i need to keep a better eye on this from now on. And also find somewhere else to buy oil. It was £47 from halfords.
PostSubject: Re: Oil Check R56   13th May 2013, 21:04
Asda sell it, £12 per litre...
PostSubject: Re: Oil Check R56   13th May 2013, 21:13
Just checked mine after reading this and I can't believe how hard the level on the dipstick is to read properly. Fortunately my mate used to be a main dealer mechanic and he's checked it for me and its ok for now.
PostSubject: Re: Oil Check R56   13th May 2013, 21:43
The oil pressure light will come on if the oil pipe is no longer in the oil which it looks like can happen in hard cornering with low oil. If that happens your engine may be wrecked in seconds so if that light comes on and it is safe to do so then turn the engine off asap and check.
Don't engage the steering lock if you're still moving though!
Always check the oil on level ground. Depending on where the dipstick enters the sump this can make a huge difference. The car should be allowed to stand for a few minutes before checking.
Also, always you the correct grade and specification of oil. Both are mega important.
PostSubject: Re: Oil Check R56   13th May 2013, 21:49
Sound advise Phil Smile
PostSubject: Re: Oil Check R56   20th May 2013, 10:55
Just dropped my car to woods hampshire to be looked at. While i was there i mentioned the oil consumption. She said MINI/BMW allow 1L per 800 miles? Is this right? It seems an awful lot of oil to use.
coopert
PostSubject: Re: Oil Check R56   20th May 2013, 19:44
Check out my thread about Super knocking mate might answer a few questions...
PostSubject: Re: Oil Check R56   30th November 2013, 11:31
I always check after2-3 fuel ups. Dipstick read is rubbish better when left to stand for a while or cold.
Try opie oils always beat hfds!
Dermottdog
PostSubject: Re: Oil Check R56   30th November 2013, 18:28
I check mine every week!! I do it in the morning after it's been in the garage overnight. A 5 minute routine that could well save you future engine problems.
PostSubject: Re: Oil Check R56   1st December 2013, 22:09
Yup thats the allowance levels
Oil Check R56
