 Rough starting JCW
PostSubject: Rough starting JCW    25th July 2013, 13:21
Hi. I took my JCW to the West Country last weekend and ever since then it has not liked starting from cold. It sounds like its on 2 or 3 cylinders and then when your rev it is pops and bangs really loudly and tries to cut out. Then after a minute or so it cures itself and runs perfectly.
Any ideas??
PostSubject: Re: Rough starting JCW    25th July 2013, 17:25
Dodgy plug maybe?
Coil pack?
Got to be electrical I'd say!
PostSubject: Re: Rough starting JCW    25th July 2013, 17:40
Oh just a thought, is it he cold start rattle?
Does it sound like a rough sounding diesel?
I've had his on my previous cars and it is alarming!
PostSubject: Re: Rough starting JCW    25th July 2013, 18:29
Yep that sounds like it. What did u do to cure it??
PostSubject: Re: Rough starting JCW    25th July 2013, 19:41
Warranty job although they will say they need to hear it which will mean leaving it!
Vines did mine last time, wanted to charge for a loan car so I contacted MINI and had a go about it being a known issue, not my fault etc. so why should I pay for a loan car? Within the hour Vines contacted me to say there was a FOC car waiting. They had it for 3 days.
Barons never used to charge me for a loan car though..
PostSubject: Re: Rough starting JCW    25th July 2013, 20:06
Ok, I'll be ringing Barons in the morning then.
PostSubject: Re: Rough starting JCW    26th July 2013, 21:59
I just get them to come and collect it and deliver it back when done. MINI want give you this option unless you ask.
flower
PostSubject: Re: Rough starting JCW    26th July 2013, 22:23
It's going in next Thursday to be checked over at Barons
PostSubject: Re: Rough starting JCW    26th July 2013, 22:49
I guess they want it over night?
PostSubject: Re: Rough starting JCW    26th July 2013, 22:58
Dropping it off Thursday after work so they can see it from cold. Got the Don't Wash Me signs ready!!!
PostSubject: Re: Rough starting JCW    26th July 2013, 23:02
I have your shirts so could see you there Friday, time depending Smile
Gazza
Member Number - SnM : SNM 415
PostSubject: Re: Rough starting JCW    27th July 2013, 09:11
Sounds like the high pressure fuel pump.
PostSubject: Re: Rough starting JCW    27th July 2013, 09:59
It'll b around 5pm dave. How much do I owe for the hoodie?
PostSubject: Re: Rough starting JCW    27th July 2013, 10:02
I've checked it again this morning and its still bad. Also checked the management system and the are no errors/faults showing so hopefully the dealer will sort it under warranty
Platty
PostSubject: Re: Rough starting JCW    27th July 2013, 12:51
As Gazza has said, i'd bet either the HPFP or the coolant sensor.
PostSubject: Re: Rough starting JCW    27th July 2013, 13:18
Broken thermostat like i had?
PostSubject: Re: Rough starting JCW    28th July 2013, 17:43
Now have an engine management warning light on. Reducing the power. Not a well JCW.
PostSubject: Re: Rough starting JCW    29th July 2013, 21:05
Do you have a code reader? There will be stored codes which should help pinpoint the problem. I'd have checked this for you if I'd seen the post earlier but I'm not around again before Thursday. Let us know how you get on.
PostSubject: Re: Rough starting JCW    30th July 2013, 13:07
No I dont have one. I have a mate who used to b a service manager for Audi and he has one. He's trying to get round tonite to check it. If not ill just let Barons (hopefully) sort it.
Gazza
PostSubject: Re: Rough starting JCW    1st August 2013, 21:47
I had the same problem on mine had the high pressure pump changed all sorted. Update yesterday same problem again my fault had a 2nd hand pump fitted getting a brand new one fitted this Saturday.
PostSubject: Re: Rough starting JCW    1st August 2013, 22:35
spoke to the technician who will be working on my car when I dropped it off earlier and he said that he was 99% sure that it will be the fuel pump. I guess I'll find out tomorrow
PostSubject: Re: Rough starting JCW    2nd August 2013, 12:05
Just had a call from Barons and it was the fuel pump. So that's been replaced as have all the pipes in the fuel system. Hopefuly thats now sorted the problem. Can't fault Barons for their work they've done everything I've asked without an issue. I only hope that they took notice of the big signs I placed in the car telling them not to wash it!!
Just picked the car up and what a difference!! The car is fantastic, so I guess that the fuel pump had been failing for a while as its never driven this well. They found other faults with the car that had been caused by the failing fuel pump so I guess all that being sorted has made the difference. Can't wait for this and next Sunday now.
PostSubject: Re: Rough starting JCW    2nd August 2013, 21:09
Pleased to hear that is sorted.
PostSubject: Re: Rough starting JCW    2nd August 2013, 21:11
This issue seems to be happening more and more!
Hope all sorted when you collect tomorrow Smile
PostSubject: Re: Rough starting JCW    2nd August 2013, 21:28
the service guy said that its a "known" fault with the JCW. But its not a recall as its not a safety issue.They will replace it only when it fails
Rough starting JCW
