 Replacement MINI badges
PostSubject: Replacement MINI badges   26th November 2014, 13:25
So Spence is a bit old and the black bit on the mini badges on the front and back are worn and the black bits coming off, I remember seeing somewhere replacement gel overlays. But I can't find them. Is there a fix or do I need new badges all together
Lilo xx
GarryS
Member Number - SnM : 248
PostSubject: Re: Replacement MINI badges   27th November 2014, 11:50
I need one for the rear of my Cooper S (R56) so am also interested; I don't want to have to buy a new badge and risk damaging paintwork during removal of the old badge if I can avoid it Shocked
PostSubject: Re: Replacement MINI badges   13th February 2015, 16:28
Bump.
I'm pretty sure there was someone on TM that made domed badges.
X
PostSubject: Re: Replacement MINI badges   13th February 2015, 23:39
PrincessRiot wrote:
Bump.
X
This is SnM not TM Li Wink lol!
PostSubject: Re: Replacement MINI badges   14th February 2015, 07:41
I know that but I'm hoping someone on here will point me in the right direction as I don't go on tm since in went down in like 2013 :p
L333 CLC
Member Number - SnM : 1007
PostSubject: Re: Replacement MINI badges   14th February 2015, 09:51
I've had a quick look on eBay, it would seem that buying the entire badge is probably the easiest thing to do - judging by the price of them it would invariably cost the same for just the insert :/
http://www.IDEAlee.co.uk
PostSubject: Re: Replacement MINI badges   14th February 2015, 12:22
There's the risk of damaging the pain otherwise. Did you fine the inserts?
GarryS
PostSubject: Re: Replacement MINI badges   14th February 2015, 13:29
Li, I ended up replacing the whole badge on the back of my R56 MCS, I used a hairdryer to make the glue on the old badge tacky then spent the next twenty minutes sawing away with dental floss. The old badge came off fairly cleanly. I then removed the glue that was left on the body with a little Meguiars Ultra-cut compound, wiped the area with an alcohol wipe, popped the new badge on and voila Shiny Shiny and no bodywork damage cheers
PostSubject: Re: Replacement MINI badges   14th February 2015, 13:43
Will my stripe add more problems to that though?
GarryS
PostSubject: Re: Replacement MINI badges   15th February 2015, 09:29
Good point; you don't want to get the hairdryer near your stripe pale
My advice then, buy a replacement badge off eBay and gently remove the new gel centre and vice versa on the original.
Sportspack Mark
PostSubject: Re: Replacement MINI badges   15th February 2015, 09:53
from memory folks the MINI badges are easily removed. Ill ask and report back.
Id be inclined to just replace it with a new badge rather than new gel bits Smile
Member Number - SnM : 460
PostSubject: Re: Replacement MINI badges   15th February 2015, 11:05
I took my mini badges off the rear of my r55 clubby last week. Piece of cake. Dental floss and some tar remover.
I still have the giant mini badge sitting on my desk Smile
Cazzywaz
Member Number - SnM : 009
PostSubject: Re: Replacement MINI badges   3rd March 2015, 13:40
Hi Li - I know I've been gone ages but the badges on Oscar have been on and off more times than a light switch. I've always removed them easily (think I used thin thread last time) then I stick them back on (or someone does for me) using 3M tape from Ebay.
