 TPMS question
s60r
PostSubject: TPMS question   28th January 2017, 07:53
Hi,
I am about to swap my turbofans for JCW split rim Ronals in black Smile
Before I go ahead can someone confirm what system the Mini uses please?
Does the valve have the TPMS unit integral so each corner is coded to the sensor or does it operate a rolling circumference calculation (done by the abs sensor) as with an old BMW I had.
The reason I ask is if the sensor is in the wheel and valve it will need to be demounted very carefully and I will have to wait until my trusted tyre fitter is available..... if no actual sensor is in the wheel then I will go locally today.
Many thanks to anyone who knows in advance.
Smile
(sept 2011 r60)
Last edited by s60r on 28th January 2017, 07:55; edited 2 times in total (Reason for editing : spelling as usual)
Forum Mod
Forum Mod
PostSubject: Re: TPMS question   28th January 2017, 09:48
Our 2013 Countryman just uses the abs sensor system as do all Gen2's as far as I know and TPMS is on Gen3's.
s60r
PostSubject: Re: TPMS question   28th January 2017, 13:38
Spot on Dave... Thank you.
TPMS question
Surrey New MINI :: MINI's, Parts & Mods :: Wheels, Tyres, Suspension & Brakes :: 2nd Gen-
