 Engine Oil
SPS2018
SPS2018
Engine Oil Vide
PostSubject: Engine Oil   Engine Oil Empty29th October 2017, 16:22
Hi All.
I have a slight rattel from Gretel's engine, the side associated with the timing chain tensioner, so I thought I would check the oil level. Good job I did, shes been stood for a week and there is nothing registering on the dip stick at all.
So I need to top up the oil at least and then get it booked in for a full oil change and a timing chain tensioner change as a precaution.
What do people recommend for a modified, fast road use, 2004 MCS?
Can get to Halfrauds tomorrow.
SPS.
http://www.htcuk.net
Engine Oil Vide
PostSubject: Re: Engine Oil   Engine Oil Empty29th October 2017, 17:23
I used to use Castrol Edge 5W30 in my R53 JCW.
Did a bulk buy when it was on offer on Amazon and still have some left.
Engine Oil Vide
PostSubject: Re: Engine Oil   Engine Oil Empty29th October 2017, 18:23
Depends when you are planning on the oil change. If very soon you might be saving a bit with something cheaper that still meet the spec as Castrol Edge isn’t cheap to only throw it away in a few days.
Engine Oil Vide
PostSubject: Re: Engine Oil   Engine Oil Empty29th October 2017, 18:25
Strangely like Neil I brought a 4lt can of Castrol Edge 0W-30 as some are known to use oil and never needed any Wink
SPS2018
SPS2018
Engine Oil Vide
PostSubject: Re: Engine Oil   Engine Oil Empty29th October 2017, 18:34
Any merit going for thicker stuff.
Read some forums saying 5/40 or even 10/40 is good as mileage increases.
Engine Oil Vide
PostSubject: Re: Engine Oil   Engine Oil Empty29th October 2017, 20:13
Give Will at TWG (club sponsor) a call tomorrow he will give you a straight answer.
SPS2018
SPS2018
Engine Oil Vide
PostSubject: Re: Engine Oil   Engine Oil Empty30th October 2017, 22:00
Massive big up for Will, good 15min chat while outside Halfrauds.
His recommendation was 5/40 and they all leak a little and have a little drinking habit.
If they don't leave any little deposits when parked, then the leaks are not an issue.
So, I'll give her a good top up and test drive tomorrow and see if the rattling stops.
He also said that on the R53 engine, the timing chain tensioner change is not as simple as the R56 is. The head needs to come off to be able set the adjuster correctly. So when the head is off the seal/gaskets can get done as well as the seals on the intercooler.
Thanks Will, if only I was close enough to use you - hummm, maybe worth it.
SPS.
Engine Oil Vide
PostSubject: Re: Engine Oil   Engine Oil Empty30th October 2017, 22:17
I don't know how far you are but I'd say worth it for honest and good service..
Member Number - SnM : 460
Engine Oil Vide
PostSubject: Re: Engine Oil   Engine Oil Empty31st October 2017, 20:57
I travelled from Wiltshire to go to Will
It’s worth it he’s honest and hard working
Engine Oil Vide
PostSubject: Re: Engine Oil   Engine Oil Empty1st November 2017, 05:50
Yeah That
Take the MINIs to Will every time
flower
SPS2018
SPS2018
Engine Oil Vide
PostSubject: Re: Engine Oil   Engine Oil Empty14th November 2017, 22:12
So,she glugged down 1.5 litres of oil, and we have a little leak, but nothing major that I can see, level stay pretty constant.
Also found the source of the rattle, not timing chain or tensioner.
Its was the pulley tensioner damper, which was only held on with a single nut, bouncing around on one of the pulleys.
Ordering a bunch of service stuff from Lohen tomorrow for a local perfomance mechanic to fit next week.
I'll start a new thread.
Engine Oil Vide
Engine Oil
