rogey Club Endorser 1
 | Subject: COOLANT LOSS?? 22nd October 2010, 16:32 | |
| Need help , i seem to be loosing coolant , i checked the bottle the other day and it was fine went on a short journey to pompey and back to fareham , when i check under the bonnent today the water level was low in fact it was empty i have topped it up again and left the car parked up over night and the bottle is empty again. wheres the water going too?? any suggestion for what might be wrong apart from a hose split somewhere as i have looked and cant seem to see any split / broken |
Moleatrude Club & Forum Manager: Admin
Location : C'larm and Surrey Join date : 2009-08-07 Posts : 5673
 | Subject: Re: COOLANT LOSS?? 22nd October 2010, 16:34 | |
| How well did you inspect the bottle? Was it replaced during the MINI re-call? It is a known problem that wasn't always fixed. |
 | Subject: Re: COOLANT LOSS?? 22nd October 2010, 16:39 | |
| bottle look fine i have checked it and water is not leaking fron there as far as i can tell |
PrincessRiot Competition Support
Location : South UK Member Number - SnM : 035 Join date : 2009-10-05 Posts : 5599
 | Subject: Re: COOLANT LOSS?? 22nd October 2010, 16:40 | |
| i had this issue, its rather mysterious, mine is ok at the moment tho |
 | Subject: Re: COOLANT LOSS?? 22nd October 2010, 16:42 | |
| I would recommend topping up the coolent after drying the entire engine bay. Then wobble all the associated pipes etc and look for leaks. If not, garage  |
Mini S Mad Club Endorser 2
Location : Somerset/Ex w.Sussex Member Number - SnM : 013 Join date : 2009-08-14 Posts : 9876
 | Subject: Re: COOLANT LOSS?? 22nd October 2010, 17:07 | |
| I had one of the pipes replaced for this issue & thought it was fine until chilli went for her MOT one year & they abdoned cause it was leaking again. Couldn't find a crack in the bottle but appeared there was a hairline around the ridge/join in the bottle. Replaced & had no probs since Have you tried filling under the ridge & above as this appears a weak point if not the pipe I got a second hand replacement from mini matt Hope this helps
 | Subject: Re: COOLANT LOSS?? 22nd October 2010, 17:23 | |
| sounds like the theromstat housing |
Jamski Club & Forum Manager: Admin
 | Subject: Re: COOLANT LOSS?? 22nd October 2010, 17:24 | |
| Could just be an air lock? Just had my rad replaced coz I had a small hole. Bottle still going down though but think it's probably just an airlock. Could be the rad, or pipe. Think the thermostat housing has a tendancy to go as well. Just keep toping up and see ho it goes.  |
Aaron
Location : Middlesex Join date : 2010-01-21 Posts : 3741
 | Subject: Re: COOLANT LOSS?? 22nd October 2010, 21:47 | |
| Like jack said I can pretty much garantee it will be the termostat housing it's the most annoying leak you can never really see it and when I took it to svg and they pressure tested it and it still didn't show up so they put this uv fluid in the system left it a week and the put a black light under the car then it stands out like a sore thumb. I put money on it that that's what it is  |
 | Subject: Re: COOLANT LOSS?? 22nd October 2010, 22:51 | |
| We had our thermostat housing replaced recently, they become porus hence the lost of coolant, argued with the dealer and MINI paid for parts & half labour as known fault |
millbrookmini Club Endorser 6
Location : South Nutfield Join date : 2009-11-15 Posts : 1885
 | Subject: Re: COOLANT LOSS?? 23rd October 2010, 07:46 | |
| - Davyboy wrote:
- We had our thermostat housing replaced recently, they become porus hence the lost of coolant, argued with the dealer and MINI paid for parts & half labour as known fault
I thought that your Clubman would have been under warranty ..... and therefore no arguments should have occurred. Is a there a web site with a simple list of all known and acknowledged faults |
Aaron
 | Subject: Re: COOLANT LOSS?? 23rd October 2010, 08:05 | |
Is a there a web site with a simple list of all known and acknowledged faults that would be a good idea but not sure if there is |
 | Subject: Re: COOLANT LOSS?? 23rd October 2010, 16:38 | |
| woops ... should have known that! |
coopert Club Endorser 1
Location : Pulborough Join date : 2009-09-29 Posts : 650
 | Subject: Re: COOLANT LOSS?? 26th October 2010, 18:15 | |
| Only way to find it really mate is to get a pressure test kit on it. Pump her up to running pressure and all will become clear!  Yours won't suffer with the coolant/ expansion tank woes as yours is different to the S and not pressurised. Mine used to spill out the top on hard cornering as it isn't a sealed lid. Thermostat housing a good bet! I would top up and check again as there is a pressure cap on the rad. intake/top. You may have been very low on fluid and just drawn in what you topped up with. The Placcy tank is just an overflow not part of the pressurised system. Did you remove the pressure cap fill the exp.tank until coolant came out of the pressure cap position, then refit the pressure cap and continue to fill? Hopefully this will solve it but you need to find that leak! Good luck mate! |
Aaron
 | Subject: Re: COOLANT LOSS?? 26th October 2010, 20:07 | |
| yeah thats good info tom but one thing is if you pressure test it its most likely that it wont show if its the thermostat houseing because when mine went it didnt show up when pressure tested because its only really letting out steam not water |
 | Subject: Re: COOLANT LOSS?? 26th October 2010, 20:20 | |
| - Aaron wrote:
- yeah thats good info tom but one thing is if you pressure test it its most likely that it wont show if its the thermostat houseing because when mine went it didnt show up when pressure tested because its only really letting out steam not water
True but if you run the pressure test cold then hot you can do 2 things; 1. Eliminate leaks from hoses, Radiator, Heater etc. first. Before you change the thermo housing. 2. Check for headgasket leak (excess Pressure build up) pressure cap relief pressure and finally confirm a hot thermo housing leak if you do the tests properly. Maybe we need to spend £30-£60 on a Surrey new mini test kit! |
Aaron
 | Subject: Re: COOLANT LOSS?? 26th October 2010, 20:26 | |
| lol yeah they should really find a better way of making them thermostat housings there so common my bosses daughters minis in for a replacement one at the moment lol |
 | Subject: Re: COOLANT LOSS?? 26th October 2010, 21:03 | |
| Why would they fix it! Repeat work.....People don't get rich off reliable cars!!!!!!!!!!!!!!!!!! |
Aaron
 | Subject: Re: COOLANT LOSS?? 26th October 2010, 21:05 | |
| - coopert wrote:
- Why would they fix it! Repeat work.....People don't get rich off reliable cars!!!!!!!!!!!!!!!!!!
very true lol |
frankie_C
Location : sutton surrey Join date : 2009-08-13 Posts : 227
 | Subject: Re: COOLANT LOSS?? 26th October 2010, 23:53 | |
| i would also say thermo stat housing as they warp they have a modified part for it about £27 +vat bit of a bugger to change tho lots of bits need to come out inluding battery battery tray air fliter housing and ecu and thats just so you can get to the 3 bolts that hold it on, i had to do mine a week after i bought it. |
mab01uk
 | Subject: Re: COOLANT LOSS?? 31st October 2010, 14:55 | |
| Heater matrix (radiator) is a common leak point to check, the coolant water ends up flooding the cavity under the carpet area in the passenger footwell so can go unoticed for a while, although you can often smell the antifreeze inside the car first. |
 | Subject: Re: COOLANT LOSS??  | |
