 Please please help :( indicators :(
Please please help :( indicators :( Vide
PostSubject: Please please help :( indicators :(   Please please help :( indicators :( Empty9th February 2011, 21:38
Drove to work today fine however in my way home my right indicator decided to speed up double the speed of the left. This also means when I have my hazards on the right one goes faster then the left. Considerabley Sad please someone tell me it's an easy fix Sad
PostSubject: Re: Please please help :( indicators :(   Please please help :( indicators :( Empty9th February 2011, 21:39
Sounds like a bulb is out somewhere Li. Stick the Hazards on and check around the car.
PostSubject: Re: Please please help :( indicators :(   Please please help :( indicators :( Empty9th February 2011, 21:47
most certainly a bulb, it will be the side that's flashing fast
PostSubject: Re: Please please help :( indicators :(   Please please help :( indicators :( Empty9th February 2011, 21:48
if it's the rear just check the plug hasn't worked loose form changing the light units
PostSubject: Re: Please please help :( indicators :(   Please please help :( indicators :( Empty9th February 2011, 22:03
As Dave and Phil have said, it'll just be a bulb that's gone Smile
Please please help :( indicators :( Jack__14
PostSubject: Re: Please please help :( indicators :(   Please please help :( indicators :( Empty10th February 2011, 15:58
bulb gone or a loose wire some where
PostSubject: Re: Please please help :( indicators :(   Please please help :( indicators :( Empty10th February 2011, 17:17
as jack said,put the hazards on and check to see whot one ant working,replace broken bulb Very Happy
PostSubject: Re: Please please help :( indicators :(   Please please help :( indicators :( Empty10th February 2011, 17:56
A blub has gone however I can't figure out how to change it and sam doesn't want to attempt it and break it haha.
Hyper Neil
Hyper Neil
what one is it Li?
PostSubject: Re: Please please help :( indicators :(   Please please help :( indicators :( Empty10th February 2011, 18:04
Rear drivers side Sad
Hyper Neil
Hyper Neil
PostSubject: Re: Please please help :( indicators :(   Please please help :( indicators :( Empty10th February 2011, 18:05
Sad cant be that hard Li
PostSubject: Re: Please please help :( indicators :(   Please please help :( indicators :( Empty10th February 2011, 18:25
go to halfords and they will change it for you if you ask them Very Happy
PostSubject: Re: Please please help :( indicators :(   Please please help :( indicators :( Empty10th February 2011, 18:30
Hope this is for your year MINI Li .......
1) Opened the access panel
2) Unscrewed the 10 mm hex nut holding in the brake light assembly
3) Detached the cable harness, pressed in the retaining springs and removed the assembly
4) Squeezed the clips to remove the bulb board (holding 3 bulbs) from the lens cover
5) Removed the brake bulb from the board (press in and rotate ~ 45 degrees)
Installation is the opposite of removal.
A note for those with BMW MINI white units.. the bulbs are soldered into the holder Rolling Eyes
PostSubject: Re: Please please help :( indicators :(   Please please help :( indicators :( Empty10th February 2011, 19:17
:s maybe you could do it Saturday for me Dave Very Happy :p
That looks all to hard and I don't want to break a nail :p
PostSubject: Re: Please please help :( indicators :(   Please please help :( indicators :( Empty10th February 2011, 19:32
As Jack said pop into a Halford to get a bulb, I don't supose you have one and I don't......
Not sure what one you need but they should be able to tell you as they will have a chart...
Just be careful when flashing right as anyone following won't know if the bulbs failed..
PostSubject: Re: Please please help :( indicators :(   Please please help :( indicators :( Empty10th February 2011, 20:15
I have a spare bulb :s
PostSubject: Re: Please please help :( indicators :(   Please please help :( indicators :( Empty10th February 2011, 20:20
I had to stick my arm out the window like the old fashioned days when mine went & the lapse b4 i could get a replacement Razz
