 Reading Lamp Bulb Swap
SpykeyMyk
SpykeyMyk
Reading Lamp Bulb Swap Vide
PostSubject: Reading Lamp Bulb Swap   Reading Lamp Bulb Swap Empty11th October 2009, 15:24
Hi Guys & Girls
I want to swap all the light bulbs in Henry Cooper for LED's I have done the Central Roof Lamp, The ones in the bottom of the doors and Footwells. Now the Problem I have managed to remove the lens off the Reading Lamp But I can't get the Bulbs out - can't get hold of them I tried Pliers but I am worried I'll break the Bulb. I asked this on TM but got no real help. Ant Ideas???
Cheers Mike
PostSubject: Re: Reading Lamp Bulb Swap   Reading Lamp Bulb Swap Empty11th October 2009, 17:10
have a search on North American Motoring, they have all the MINI fitting guides for staff Smile
https://surreynewmini.forumotion.com
Matt
Matt
PostSubject: Re: Reading Lamp Bulb Swap   Reading Lamp Bulb Swap Empty20th May 2010, 14:29
I don't know if you got a decent answer anywhere but I just did this and my method worked first time.
I got a pair of long nose pliers and put some double sided tape on the ends and pulled the bulbs out easy! I used the sort of tape that one would affix a number plate with.
Hope that helps,
Matt
PostSubject: Re: Reading Lamp Bulb Swap   Reading Lamp Bulb Swap Empty20th May 2010, 14:30
Watch out they get hot very quickly - as my hand found out when i changed them on my 2nd GEN Embarassed
SpykeyMyk
SpykeyMyk
PostSubject: Re: Reading Lamp Bulb Swap   Reading Lamp Bulb Swap Empty20th May 2010, 15:54
Hope that helps,
Matt
I did something Similar - I got a length of duct tape wrapped it round the bulb ieaving a kind of tail to get hold of and Just tugged came out first time Cheers anyway Matt thumbs up
Matt
Matt
PostSubject: Re: Reading Lamp Bulb Swap   Reading Lamp Bulb Swap Empty20th May 2010, 16:04
thumbs up
PostSubject: Re: Reading Lamp Bulb Swap   Reading Lamp Bulb Swap Empty20th May 2010, 18:36
Genius initiative there Mike Very Happy
