PepperMini214
Location : Sutton, Surrey Join date : 2011-12-12 Posts : 69
 | Subject: Petrol Light! 9th February 2012, 14:14 | |
| so recently, with it being so cold, i have been being lazy and letting the petrol get down to the red light.. but after putting petrol in a few times since it first happened. the light wont turn off no matter how much petrol i seem to put in.. any ideas why this could be? |
tazman Club Endorser 2
 | Subject: Re: Petrol Light! 9th February 2012, 17:17 | |
| looks like the flot has stuck,if you let it go down to much it mite have got stuck,i would try fill your tank full to see if that work if not bmw here you come, |
PepperMini214
 | Subject: Re: Petrol Light! 9th February 2012, 17:30 | |
| Ok I will try that.. |
 | Subject: Re: Petrol Light! 9th February 2012, 17:50 | |
| Not sure where the sender in located on you MINI, I know in the tank, but wondered if a wire has come adrift! |
 | Subject: Re: Petrol Light! 9th February 2012, 18:06 | |
| - Davyboy wrote:
- Not sure where the sender in located on you MINI, I know in the tank, but wondered if a wire has come adrift!
dave i think if you remove the rear seat you can get to it from there,but i bet you a beer its just stuck,and if she fills it up it will be ok,   " border="0" alt=""/> ps if you do need a NEW one here is a link, http://www.ebay.co.uk/itm/NEW-BMW-MINI-One-Cooper-S-R50-R52-R53-fuel-level-sensor-sender-16146765134-/290667866057?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43ad27a7c9 |
 | Subject: Re: Petrol Light! 13th February 2012, 17:54 | |
PepperMini214
 | Subject: Re: Petrol Light! 13th February 2012, 18:00 | |
| I get the train to work everyday so haven't driven yet but I will let you know... |
 | Subject: Re: Petrol Light! 13th February 2012, 18:11 | |
| - PepperMini214 wrote:
- I get the train to work everyday so haven't driven yet but I will let you know...
i was talking to gary today and he had the same with his car once he said he filled it up around 3/4 and kept going round a roundabout and it did work in the end  it works on yours. |
PepperMini214
 | Subject: Re: Petrol Light! 13th February 2012, 19:02 | |
| Just filled it to the brim and it's gone off! Thank goodness and thanks rich !! ... Now to worry about my new problem ... |
 | Subject: Re: Petrol Light! 13th February 2012, 19:05 | |
| what's the new problem now.????????????????? |
PepperMini214
 | Subject: Re: Petrol Light! 13th February 2012, 19:19 | |
| No second gear! Either won't go in at all or grinds in with a bit of force! Is a new gear box looking likely? And how am I looking at paying for a new one?? |
 | Subject: Re: Petrol Light! 13th February 2012, 19:55 | |
| think i have seen this prob some where before,do you have a 5 speed or 6 speed box,coz i know the had probs with the 5 speed box,can' realy help sorry,but someone on here will im sure,put a new topic up and see if anyone know's or can help. |
PepperMini214
 | Subject: Re: Petrol Light! 13th February 2012, 20:03 | |
| 5 speed.. thanks! will post a new topic up now... |
Marque Club Endorser 3
Location : Everywhere apart from where I am meant to be Join date : 2011-04-18 Posts : 130
 | Subject: Re: Petrol Light! 13th February 2012, 20:24 | |
- No second gear!
What year is your car if it before July 04 it will have a midland 5 speed gear box after july 04 they changed to Getrag 5 speed gear box Midland gearboxes had lots of problems, you can retro fit a Getrag but it's a lot of work and parts. Rebuild kits are easy to get hold of from eBay there about £250 Mark or a recon or a secondhand gear box around the £350 to £400 But it still means you strip out the gear box do the job and refit it Does it go in to gear ok when the engine is not running or does feel notchy But first I would get someone to check the linkages and gear change cables first then change the gearbox oil and see if you have a lot of metal in it. How does the clutch pedal feel does it feel soft or spongy |
 | Subject: Re: Petrol Light!  | |
