 Voice command button
wlondoner
wlondoner
Member Number - SnM : 36
Voice command button Vide
PostSubject: Voice command button   Voice command button Empty24th June 2012, 23:17
Sorry this might seem dumb but I dont get this - does it work on every model? - what am I meant to do?
Its on my steering wheel, the manual doesnt really tell me much!?!
PostSubject: Re: Voice command button   Voice command button Empty24th June 2012, 23:22
It only works if you have bluetooth I think Craig Smile
PostSubject: Re: Voice command button   Voice command button Empty24th June 2012, 23:37
Not sure about that Ian, my first clubbie had the button but it didn't work whereas the other two have worked Smile
Maybe it just didn't work but dealer said it wasn't a fitted option but did have bluetooth although only basic scratch
PostSubject: Re: Voice command button   Voice command button Empty24th June 2012, 23:52
I've had an r56 with full bluetooth and that had the voice button which worked... I think you pressed it and held it for a few seconds then it would ask you to speak. Worked really well when there was just me in the car, although it didn't seem to work for some reason when I had passengers!
PostSubject: Re: Voice command button   Voice command button Empty25th June 2012, 00:07
Hmm not sure then Dave! I had bluetooth in my old Checkmate and the button worked in that too Smile
wlondoner
wlondoner
PostSubject: Re: Voice command button   Voice command button Empty25th June 2012, 00:09
I need to try it again tomorrow.
I dont get why the button is there if it doesnt work!
PostSubject: Re: Voice command button   Voice command button Empty25th June 2012, 00:15
It's just a standard button with the MFSW Smile
Mike
PostSubject: Re: Voice command button   Voice command button Empty25th June 2012, 01:06
Works good for me. I can ask it to call someone and ............. that what it does Smile
PostSubject: Re: Voice command button   Voice command button Empty25th June 2012, 05:40
Worked for phone use only on my Cooper D with Basic Bluetooth.
On my S with Full Bluetooth & Nav it navigates through most options on the Nav / radio / Phone / Setup menus.
Start1980
PostSubject: Re: Voice command button   Voice command button Empty28th October 2012, 10:40
Hi, Newbie on here. I originally had a 2009 Cooper D with Full Bluetooth and the voice control button worked fine. I requested that the dealer specced my new cooper d withe the same full bluetooth and some other extras.
Took delivery on Friday and the voice control button does not work, although the telephone button does. Dealer says that I need Visual boost radio. The brochure that I placed order from at the time back on August said that Voice control costs "£0" when ordered with full bluetooth.
Any ideas, the car is pretty useless if I have to pull over or risk a fine every time I need to call someone?
Can it be retro fitted. The dealer showed me an internal bulletin from last week saying that the option no longer worked with just the audio boost. Someone has cocked up as I say my order was placed in August.
Can anyone offer any help/advice please?
PostSubject: Re: Voice command button   Voice command button Empty28th October 2012, 15:23
Hi Craigy
PM Martin (mjnewham) hes a real teci and showed me how to do stuff with mine. He your man
Chris
flower
mjnewham
mjnewham
Member Number - SnM : 203
PostSubject: Re: Voice command button   Voice command button Empty28th October 2012, 16:10
It's a tough question, I found that Mini isn't always clear with the more technical options. I would contact either Mini Park Lane; the only 'Offical' Mini dealer (others are fanchises) or try contacting Mini UK direct. The customer services are very good.
https://facebook.com/mjnewham
Member Number - SnM : 029
PostSubject: Re: Voice command button   Voice command button Empty28th October 2012, 16:15
Voice control should come with full bluetooth and armrest; at least it always has! Shame if they changed it. Mind you, I never used it when I had it - was always easier just to scroll to number on the OBD with MFSW controls.
Start1980
PostSubject: Re: Voice command button   Voice command button Empty28th October 2012, 17:27
Thanks. My point is that also, I ordered the car before they sent the bulletin to the dealers.
Mike
PostSubject: Re: Voice command button   Voice command button Empty28th October 2012, 20:23
They need to fit the full kit FOC then Smile ring Mini UK they will get it sorted for you... Don't wait to long Smile
Start1980
PostSubject: Re: Voice command button   Voice command button Empty29th October 2012, 21:27
Thanks everyone. Mini UK looking into it for me. Dealer says they will back me as it seems that Mini UK changed the spec but did not tell the dealer! Not sure what can be done but I don't want any type of aftermarket kit . . .
wlondoner
wlondoner
PostSubject: Re: Voice command button   Voice command button Empty12th May 2013, 23:28
Ok so bringing up this old post again
I have this button in my new mini there isnt much about it in the handbook at all (same as my old mini)
I saw a review on the MINI on youtube and he pressed it and said play CD and it did - but it seems to be on telephone mode when I press it? I dont want telephone...
Anyone know any more on this button?
PostSubject: Re: Voice command button   Voice command button Empty12th May 2013, 23:31
It'll only give you full voice control if the car has it specced. If it doesn't, then it'll only work for the phone options Smile
Mini99
Member Number - SnM : 099
PostSubject: Re: Voice command button   Voice command button Empty13th May 2013, 00:07
I have this button.... Never pressed it, I forgot about it.... Now I'm wondering if it actually does anything.... How would I even know if it has Bluetooth?
PostSubject: Re: Voice command button   Voice command button Empty13th May 2013, 06:44
I have it and it just tells me to "shut up and do it myself" lol!
As Ian said it has to be spec'd to be able to use on all systems....
PostSubject: Re: Voice command button   Voice command button Empty13th May 2013, 06:46
Has your phone got Bluetooth Dee? If so use it to do a search when in the car and it will find it if you have it...
Or pop into the dealer with VIN no. and they can tell you the spec Smile
PostSubject: Re: Voice command button   Voice command button Empty13th May 2013, 13:12
All mine says is "sorry I didn't understand that command". Easier and quicker to do it manually.
Mini99
PostSubject: Re: Voice command button   Voice command button Empty13th May 2013, 13:38
I don't have one of those screen thingymebobs in my car so I guess it's just a useless button haha
emu-p
emu-p
Member Number - SnM : SnM086, PW011, NmS008
PostSubject: Re: Voice command button   Voice command button Empty13th May 2013, 14:07
Try speaking in German! What a Face
wlondoner
wlondoner
PostSubject: Re: Voice command button   Voice command button Empty13th May 2013, 14:26
Mine works on telephone mode but its a bit complicated
Im not sure what else these 2 buttons do yet
Discovered I have PDC today aswell - all this tech Very Happy - my audi hardly had any in it!
