| Seatbelt Buckle Damage to Door Liner | |
GoldieJCW Club Endorser 2
Member Number - SnM : 336 Join date : 2012-08-01 Posts : 206
 | Subject: Seatbelt Buckle Damage to Door Liner 8th November 2012, 16:02 | |
| Hi I have the new style recaro seats fitted and I have noticed that it can be a real struggle to get the seatbelt buckle between the door and the edge of the seat (there really isnt much room). So, I have been taking extra care - as it seems to me that after a while the buckle is going to damage the door liner. However, now I have discovered a tiny nick in the material covering the door right up by the window.... I was a little mystified as to how it could have happened.... until I just took my seat belt off and noticed with horror how the buckle can bash into it as it goes up over the shoulder. So,,, the tiny nick should be easy to fix with a dab of glue and something to push the material back down.... but I am concerned about it happening again.. are there any replacement door card covers out there?? Or better still something which can be fitted over the top of it in this corner? Goldie |
 | Subject: Re: Seatbelt Buckle Damage to Door Liner 8th November 2012, 17:34 | |
| Never seen anything! I have had this happen on another make of car and was very annoyed and could only glue it back like you say! Just need to be very careful, is there room to put some foam or similar where it hits? |
Chris D Club Endorser 2
Location : Lower Earley, Reading Member Number - SnM : 137 Join date : 2010-08-29 Posts : 5528
Location : United Kingdom Member Number - SnM : 786 Join date : 2012-04-17 Posts : 2169
 | Subject: Re: Seatbelt Buckle Damage to Door Liner 10th November 2012, 09:03 | |
| Me having recaros in my JCW I literally lower of myself into them due to the side bostlers What i do before getting out is unclip the belt and make sure it sits on the seat with the shoulder of the seat holding the seat belt |
 | Subject: Re: Seatbelt Buckle Damage to Door Liner 10th November 2012, 09:50 | |
| On the R53 you get a little plastic slidy thing that you can use to adjust the seatbelt buckle height resting point - you might be able to get somewhere if you adjust that... Works on my r53 with jcw seats and on my r50 without... |
miffy Club Endorser 3
Location : warwickshire Join date : 2012-09-23 Posts : 1799
 | Subject: Re: Seatbelt Buckle Damage to Door Liner 10th November 2012, 10:13 | |
| I hold onto the clasp of mine when I undo it and feed it back to the anchor point so it doesnt whack the door. |
 | Subject: Re: Seatbelt Buckle Damage to Door Liner 10th November 2012, 12:58 | |
| - Moon wrote:
- On the R53 you get a little plastic slidy thing that you can use to adjust the seatbelt buckle height resting point - you might be able to get somewhere if you adjust that... Works on my r53 with jcw seats and on my r50 without...
Got that in mine but only on the drivers side! |
 | Subject: Re: Seatbelt Buckle Damage to Door Liner 10th November 2012, 14:44 | |
| I've got it on all 4 (or 8 if you include the r50) #firstgenwins!!!!! |
 | Subject: Re: Seatbelt Buckle Damage to Door Liner 10th November 2012, 15:41 | |
| - Moon wrote:
- I've got it on all 4 (or 8 if you include the r50)
#firstgenwins!!!!! It's also on my rears! Maybe the passenger one was missed? |
 | Subject: Re: Seatbelt Buckle Damage to Door Liner 10th November 2012, 17:08 | |
| Sounds like it! How strange! Cost cutting maybe?! |
PhilK Club Endorser 10
Location : Ewell Member Number - SnM : 073 Join date : 2010-02-04 Posts : 7176
 | Subject: Re: Seatbelt Buckle Damage to Door Liner 12th November 2012, 10:34 | |
| When I remember, I put the buckle in the recess in the pillar that houses the seatbelt. Seems to fit quite snugly in there. |
 | Subject: Re: Seatbelt Buckle Damage to Door Liner 28th November 2012, 17:52 | |
| Hi I have been using the feed it back in by hand method..... no more annoying damage to date. I also clip the buckle into the recess - as it stops rattles on the passenger side. |
 | Subject: Re: Seatbelt Buckle Damage to Door Liner  | |
