 Stop start ?!?
stevetigersix
stevetigersix
Member Number - SnM : 307
Stop start ?!? Vide
PostSubject: Stop start ?!?   Stop start ?!? Empty19th December 2012, 16:49
Hi all
Just a query, I've a end 2011 R57 lci MCS which has stop start on it. However it seems to be very very tempramental, sometimes it engages sometimes it just refuses and the engine continues, I've turned it off and on again, is there some sort of secret to get it to function or is it just pot luck if the winds blowing in the right direction ?
Stop start ?!? Vide
PostSubject: Re: Stop start ?!?   Stop start ?!? Empty19th December 2012, 17:30
Personally I hate it!
There are lots of sensors that will not allow it to work, most likely at present is the outside temperature! Could be low battery if you have lights, heater and A/C on!
Stop start ?!? Vide
PostSubject: Re: Stop start ?!?   Stop start ?!? Empty19th December 2012, 18:37
Start/stop works under current parameters
Outside temp and Engine temp
I am sure it working fine
Stop start ?!? Vide
PostSubject: Re: Stop start ?!?   Stop start ?!? Empty19th December 2012, 19:11
There are many reasons why it doesn't kick in. None I can fathom. Under 4 degrees is definately one where it doesn't kick in. There have been times where I've wiorried it didn't work on the S and the D, but both times it was my paranoia!
miffy
miffy
Stop start ?!? Vide
PostSubject: Re: Stop start ?!?   Stop start ?!? Empty19th December 2012, 20:30
You can turn it off if it is driving you bonkers.. Very Happy
GoldieJCW
GoldieJCW
Member Number - SnM : 336
Stop start ?!? Vide
PostSubject: Re: Stop start ?!?   Stop start ?!? Empty19th December 2012, 23:00
Mine gets turned off.... no way I want to put my engine through the constant start stop process to save me a Pound or two of fuel each week
Stop start ?!? Vide
PostSubject: Re: Stop start ?!?   Stop start ?!? Empty19th December 2012, 23:59
Buy an auto. Problem solved Very Happy
stevetigersix
stevetigersix
Stop start ?!? Vide
PostSubject: Re: Stop start ?!?   Stop start ?!? Empty20th December 2012, 07:24
Cheers for the replies, just must be the fact conditions at the moment don't favour it kicking in, also don't think it works at all if I'm in sport !?, could be wrong though ! lol!
Stop start ?!? Vide
PostSubject: Re: Stop start ?!?   Stop start ?!? Empty20th December 2012, 11:35
I think it is 3 degrees centigrade and below that it won't kick in.
It also won't kick in if the engine is not up to temperature, if you have climate control and the cabin temperature is below or above that set, if the battery needs charging (note the battery will normally only charge on the overrun so may not charge on a long run) etc.
If you want to test it then charge the battery and drive the car for a few miles and provided that the outside temperature is 4 or above then it should work.
I had a fault with the voltage sensor on the battery lead which stopped mine working. This will a fault code so if you have a code reader you can check this.
Madpig
Madpig
Member Number - SnM : 356
Stop start ?!? Vide
PostSubject: Re: Stop start ?!?   Stop start ?!? Empty24th December 2012, 08:35
I don't think there's anything wrong with yours as mine is very similar......under 4 degrees the engine doesn't stop and if it's not warmed up are the two main occasions for me.
On another point, I've noticed that if you stop at a junction when the wipers are on fully they stop too and only work intermittantly!
Stop start ?!? Vide
PostSubject: Re: Stop start ?!?   Stop start ?!? Empty24th December 2012, 08:43
They came from the BMW parts bin, had that feature back in the 90's on a 3series Smile
mjnewham
mjnewham
Member Number - SnM : 203
Stop start ?!? Vide
PostSubject: Re: Stop start ?!?   Stop start ?!? Empty25th December 2012, 19:58
From what I remember you also have to have the handbrake on and clutch off.
https://facebook.com/mjnewham
Madpig
Madpig
Stop start ?!? Vide
PostSubject: Re: Stop start ?!?   Stop start ?!? Empty25th December 2012, 21:05
Mine doesn't need the handbrake on to enable stop start........I often pull up at traffic lights and leave the handbrake off if the road is level...
banditloon
banditloon
Member Number - SnM : 251
Stop start ?!? Vide
PostSubject: Re: Stop start ?!?   Stop start ?!? Empty25th December 2012, 22:00
The Stop / Start thing in Dinky decided to work on Monday for the first time since Spring time!!
I forgot the car had it fitted....
http://www.loonrunning.co.uk
Stop start ?!? Vide
Stop start ?!?
