 Creaking Noise in Rear Left
ordidge2
ordidge2
Member Number - SnM : 386
Creaking Noise in Rear Left Vide
PostSubject: Creaking Noise in Rear Left   Creaking Noise in Rear Left Empty4th March 2013, 20:26
Hi all,
I have noticed today that I am getting a creaking sound in the rear left of the car, not sure if its there all the time but it seems to be certainly at low speeds. I'm not sure if its the bushings or the suspension its self, ill hopefully get it on the jacks/ramp at the weekend. Anyone had any ideas or experiences? (I have a 08 Dooper, if that helps)
Cheers
TO
https://www.facebook.com/ordidge2
PostSubject: Re: Creaking Noise in Rear Left   Creaking Noise in Rear Left Empty4th March 2013, 20:56
Mine makes a knocking noise at low speed on big bumps. but there's nothing wrong with it apparently - had it inspected at mini, although mine is an 05/54...
PostSubject: Re: Creaking Noise in Rear Left   Creaking Noise in Rear Left Empty4th March 2013, 20:58
I had that
Its the bloody spare wheel or tool kit in the boot
ordidge2
ordidge2
PostSubject: Re: Creaking Noise in Rear Left   Creaking Noise in Rear Left Empty4th March 2013, 21:06
AM_AUTOS wrote:
I had that
I'll check that, was it anything specific in the tool kit? Strange as its at the rear left and not in the centre at the rear
PostSubject: Re: Creaking Noise in Rear Left   Creaking Noise in Rear Left Empty4th March 2013, 21:36
it needs to be pushed down firmly or attached properly depending on your MINI
sambrad94
sambrad94
PostSubject: Re: Creaking Noise in Rear Left   Creaking Noise in Rear Left Empty14th August 2014, 09:40
A very common fault we see at sytner sunningdale is rear anti-roll bar bushes knock generally you can tell if you put the car up in the air and grab anti roll bar either side and try to slide it if it moves you need to replace the bushes they are only about £20 from the dealer
TWG-Automotive
SnM Sponsor
SnM Sponsor
TWG-Automotive
PostSubject: Re: Creaking Noise in Rear Left   Creaking Noise in Rear Left Empty14th August 2014, 11:17
I would say it was the anti roll bar bushes to. Very common and we do loads of them, around £50 fitted including VAT.
Creaking Noise in Rear Left TWGAutomotiveBanner
TWG Automotive Website
http://www.twgautomotive.co.uk
