 Big brake kits
GTTtunedMCS
Member Number - SnM : 400
Big brake kits Vide
PostSubject: Big brake kits   Big brake kits Empty27th April 2013, 17:48
Was toying with going down the GTT / Porsche big brake kit route, however this comes in at £1395+vat which is a whopping £1674 all in plus fitting unless you're mechanically minded. By accident, I've now come across a company called K Sport who have links with the Time Attack race series offering an even larger 8 pot 356mm set up for £999 inc vat, with only extra req'd being pads. Anyone heard of or used these people?
If they are any good, they'll be gracing my MINI within the next year. Would go mad & fit their 8pot 400mm set up but that's just a tad pricey at £2595! Would imagine you could stop on a coin with them though & even the 356mm set up should put JCW/Brembo set ups to shame.
pocket rocket
Member Number - SnM : 391
Big brake kits Vide
PostSubject: Re: Big brake kits   Big brake kits Empty27th April 2013, 18:49
Hiya Colin , you should have a word with Roland at gtt,s he supplied and fitted , ate , big brake conversion , to my cooper s , not sure if he still stocks them , they been ok , but pads are £113 a set . Ford,s are now fitting ate brakes to the new st,s . The kit was £995 , and seemingly the discs never warp or wear .
GTTtunedMCS
Big brake kits Vide
PostSubject: Re: Big brake kits   Big brake kits Empty27th April 2013, 20:35
Thanks Danny, getting a Bilstein B12 JCW suspension kit fitted by Roland next weekend (which might get upgraded to Bilstein B14 PSS coilovers ) so will ask him then about the ATE kit, he only seems to do Porsche now though. K sport seems worth a look though!
Big brake kits Vide
Big brake kits
