pudders Club Endorser 1
 | Subject: Arm rest 22nd October 2013, 22:42 | |
| Hi all, just go my mini and the it has a arm rest from BMW, the top sliding part Noah's broken so it won't stay shut. Does any one know where I can get a new top. Thank you Scott |
 | Subject: Re: Arm rest 22nd October 2013, 23:15 | |
| Is it the OEM one or a MINI aftermarket one? sounds like the first! TBH even with the clip they don't stay shut, My first 2 MINI's weren't great, this one is a bit better! Not sure if you can get the part from MINI if not try a breaker  |
Location : Worthing, West Sussex Member Number - SnM : 118 Join date : 2009-11-26 Posts : 16967
 | Subject: Re: Arm rest 22nd October 2013, 23:44 | |
| There are some little sort of lugs/clips, which hold it closed, it's probably those which have snapped or something. You can buy replacement tops, here's a link to realoem which shows the individual parts, it's possibly just number 3 you need  http://www.realoem.com/bmw/showparts.do?model=MF72&mospid=49645&btnr=51_6289&hg=51&fg=35 |
 | Subject: Re: Arm rest 23rd October 2013, 07:41 | |
| Yeah it's a bmw one. I took the top off and you can see there's two plastic bits broken. I am ideally not a big arm rest fan but it's In there so might as well keep. Thank you for your help. Would b a good thing to fix. It's a pain when you pull away it slides back. |
 | Subject: Re: Arm rest 23rd October 2013, 21:36 | |
| Hopefully you can just buy the top bit, if you ask at the dealers they'll be able to check with your reg/vin and make sure it's the right part number, as well as give you a price  |
 | Subject: Re: Arm rest 23rd October 2013, 21:50 | |
| If you can't get one maybe keep it shut with some blutac |
 | Subject: Re: Arm rest 23rd October 2013, 21:57 | |
| Haha might just get stuck some how. Not bothered about it being in use as in putting things in it. |
dave_a
Location : Swanley, Kent Join date : 2012-04-08 Posts : 153
 | Subject: Re: Arm rest 24th October 2013, 20:14 | |
| My oem one drove me mad so I actually took it our myself and sold it on. Was always hitting my elbow on it, just got in the way. Its pretty easy if you wanted to talk it out but you'll need extra parts |
supa-dupa
 | Subject: Re: Arm rest 24th October 2013, 21:30 | |
| You can order the bits separately for the armrest, I did. Have a look on www.realoem.com for the part number  |
GTTtunedMCS
Location : Newbury, Berks. Member Number - SnM : 400 Join date : 2013-04-22 Posts : 123
 | Subject: Re: Arm rest 30th October 2013, 21:50 | |
| I've got an armrest I'm selling if you want some bits ..... |
 | Subject: Re: Arm rest 30th October 2013, 22:03 | |
| Yeah desperate from bits for it. |
 | Subject: Re: Arm rest  | |
