This worked for me & haven't squealed since
Pull off the chrome window strip from the wing mirror end
Rinse the felt section under water & allow to dry
If you look into the inside of the door nearer the wing mirror you see a cog with wire wrapped around it this is your window regulatr spray the cog with either wd40 or oil spray & allow to run into door cavity. Allow to penetrate for a couple of mins b4 opening & closing the window a few times Untill squel stops. Have a rag handy to wipe excess of your window for a few uses
Hope that helps
