| 1st fault squeaky windows | |
justelfie Club Endorser 5
Location : Dorking Member Number - SnM : 381 Join date : 2013-01-18 Posts : 355
 | Subject: 1st fault squeaky windows 10th May 2015, 09:09 | |
| I've noticed this fault has occurred on other members minis, I tried lubricating the window channel runners whilst it made a small difference they still squeak, I've now booked it into to Chandlers before warranty ends. Chandlers said over the phone it may require new regulators fitted, has any one else the problem cured and what did they do. |
TWG-Automotive SnM Sponsor
 | Subject: Re: 1st fault squeaky windows 11th May 2015, 14:41 | |
| Yes sounds like regulators. A new pair should fix it. _________________ TWG Automotive Website |
PhilK Club Endorser 10
Location : Ewell Member Number - SnM : 073 Join date : 2010-02-04 Posts : 7176
 | Subject: Re: 1st fault squeaky windows 11th May 2015, 21:40 | |
| As will says, had the same happen on my Cooper D and the regulators were supplied under warranty. |
supa-dupa
 | Subject: Re: 1st fault squeaky windows 13th May 2015, 17:10 | |
| I had a squealing drivers window on my Cabrio, it wasn't the regulator, but they did something to/replaced the guide clips or something...apparently its a known thing as there is an internal BMW PUMA Report for it  |
 | Subject: Re: 1st fault squeaky windows 19th May 2015, 10:17 | |
| Thanks for everyone's input I will let you all know what Chandlers find when it goes in tomorrow. |
 | Subject: Re: 1st fault squeaky windows 20th May 2015, 23:43 | |
| - supa-dupa wrote:
- I had a squealing drivers window on my Cabrio, it wasn't the regulator, but they did something to/replaced the guide clips or something...apparently its a known thing as there is an internal BMW PUMA Report for it
 Hi supa dupa That now the cars in Chandlers they phoned today and mentioned something about they had to order guide clips, I will know more hopefully tomorrow, so looks like you are right. Update: After checking the paperwork they also fitted regulators as well !
supa-dupa
 | Subject: Re: 1st fault squeaky windows 23rd May 2015, 10:20 | |
| Good stuff! Mine is completely squeal free now  |
 | Subject: Re: 1st fault squeaky windows 30th May 2015, 01:10 | |
| Not so good news the car has to go back next Tuesday to Chandlers it looks like they may have inadvertently broken part of door trim clip during the repair, trim now keeps popping undone on the door handle |
Roger34 Club Endorser 6
Location : Friston, Near Eastbourne Member Number - SnM : 408 Join date : 2013-06-08 Posts : 1201
 | Subject: Re: 1st fault squeaky windows 30th May 2015, 08:42 | |
| That's a pain Dave, hope they sort it. |
 | Subject: Re: 1st fault squeaky windows 30th May 2015, 15:34 | |
| - Roger34 wrote:
- That's a pain Dave, hope they sort it.
Yes Roger its just the distance to go that's the pain just to rectify the door trim, Chandlers did also changed the front number plate because the original looked so faded. |
 | Subject: Re: 1st fault squeaky windows  | |
