 Slow acceleration from 4000 RPM
gmcnaugh
Slow acceleration from 4000 RPM Vide
PostSubject: Slow acceleration from 4000 RPM   Slow acceleration from 4000 RPM Empty30th August 2015, 16:22
Hi,
For a while now I have noticed that it is difficult to get our 2008 MCS R56 to rev much past ~4300 RPM in 3rd, 4th, 5th & 6th gears. Acceleration is way down and the car has lost its usual punch. Also (and this just may be me becoming paranoid) there is a turbo like whistle at lower constant revs. The dump valve can still be heard on changing gear and I think we are getting more crackle and pop from the exhaust (no complaints on that front though). It doesn't appear to be using any more oil than usual and the acceleration is fairly smooth, ie no stutters and idles well. Took the inlet manifold off today and there is some carbon build up but I've seen worse and I intend cleaning it when I have more time. I tend not to think the issue is being caused by carbon build up as I do not have any of the other symptoms. But am willing to be proved wrong.
Searching around the interweb there are a (very) few people reporting the same issue but either they have bailed out of the post without saying how it was ultimately cured or the fixes entail taking the car to the stealers. I would rather satisfy myself first that it is not something I can handle myself.
Any assistance gratefully received.
Last edited by gmcnaugh on 31st August 2015, 09:24; edited 1 time in total (Reason for editing : Seem to have lost the last paragraph and added the model.)
Jelster
Jelster
Member Number - SnM : 011
PostSubject: Re: Slow acceleration from 4000 RPM   Slow acceleration from 4000 RPM Empty30th August 2015, 22:10
Not sure which model Mini you have, but I had something similar on my R56 JCW, and it was a leaky pipe to/from the turbo. Admittedly it did happen further down the rev range, but it ran on tick over and up to around 3K fine, it was only when the engine "relied" on the turbo that was an issue.
gmcnaugh
PostSubject: Re: Slow acceleration from 4000 RPM   Slow acceleration from 4000 RPM Empty30th August 2015, 22:30
Hi Jelster, meant to add to my post that the car is an 08 S. When you say leaky pipe was it loose or split. Could air be felt leaking from it?
Jelster
Jelster
PostSubject: Re: Slow acceleration from 4000 RPM   Slow acceleration from 4000 RPM Empty30th August 2015, 22:33
It was a split pipe, which had worked lose. It ended up running really lumpy on the day it was due to go in the workshop. They sorted it before lunch, and it wasn't the only one they had seen...
