78007
Join date : 2019-09-25 Posts : 24 Points : 34 Reputation : 0
 | Subject: stop start facilty 1st October 2019, 09:05 | |
| Got my countryman on Friday what a really well made machine, can anyone help can the automatic stop start switch be made to default to the off posistion every time i start it I have to press the auto stop start to off so the orange light appears can it be made to go to this position on start up. |
Location : Ash Vale Member Number - SnM : 007 Join date : 2009-08-12 Posts : 22844 Points : 24708 Reputation : 604
 | Subject: Re: stop start facilty 1st October 2019, 09:50 | |
| I’m not aware of a way but I’ve seen a MINI where it had been reversed so you had to toggle the switch to turn it on. I was told it was done by a dealer. You do get used to automatically turning off each trip though. _________________  "Life's too short not to!!" |
78007
 | Subject: Re: stop start facilty 1st October 2019, 10:24 | |
| Thanks for the reply I have to go back in at weekend to the Mini dealer I will ask them if it can be done. But toggle to turn on is what i'm looking for, the wife drives it daily and she would like to get in and forget about it. She does not like it stop starting. |
 | Subject: Re: stop start facilty 1st October 2019, 11:08 | |
| Just remembered you have a F series the one I spoke about was a R series. I’m sure it can be done but if a dealer will is a different story. _________________  "Life's too short not to!!" |
Location : Worthing, West Sussex Member Number - SnM : 118 Join date : 2009-11-26 Posts : 16631 Points : 19000 Reputation : 554
78007
 | Subject: Re: stop start facilty 1st October 2019, 14:06 | |
| Hi do I have to ask what's Bimmercode, how do i get this etc? |
 | Subject: Re: stop start facilty 1st October 2019, 14:55 | |
| It's a coding app that you can use to code certain things in BMW/MINI/Rolls-Royce. You need the app and an OBD adapter, the app then connects via WiFi to it and allows you to program different things - https://bimmercode.app There are also coders around that can probably do it for you, one that springs to mind is DD Coding, he seems to get good reviews and can code remotely too I think. |
78007
 | Subject: Re: stop start facilty 1st October 2019, 14:59 | |
| I have been looking on the web and clicked on your link to the app, can you recommend an OBD adaptor too many on eBay etc. not sure which one to get, it looks a great way of changing things, thanks a lot for your help. |
78007
 | Subject: Re: stop start facilty 2nd October 2019, 07:26 | |
| Hi Ian read your reply it says at the top of the web page there is a link may be me but can't see any link to a web page am i stupid? The wife is really liking the Mini we thought the brake assist was when the handbrake was on and it released when you moved off, she only realised the brakes actually hold the vehicle for a couple of seconds, when hand brake off. |
78007
 | Subject: Re: stop start facilty 2nd October 2019, 08:05 | |
| Hi Ian yep me stupid I have seen the adaptor link on the app page Cheers |
 | Subject: Re: stop start facilty 2nd October 2019, 10:06 | |
| - 78007 wrote:
The wife is really liking the Mini we thought the brake assist was when the handbrake was on and it released when you moved off, she only realised the brakes actually hold the vehicle for a couple of seconds, when hand brake off. Brake assist can be handy, works when facing down hill as well as up. My view of driving away with the handbrake on and relying on the auto release is not what I do as it can cause early rear brake wear as does using the cruise control. Good to hear your wife is enjoying the MINI CM .. _________________  "Life's too short not to!!" |
78007
 | Subject: Re: stop start facilty 2nd October 2019, 11:39 | |
| I have ordered an adaptor I'm hoping I can code the auto stop start to default to off, and maybe make the Mini make a noise when the car is locked, |
 | Subject: Re: stop start facilty 2nd October 2019, 14:12 | |
| You can definitely code it to beep when you lock/unlock it, I've coded it on my F56. These are the coding options for the F models, which also tells you where to go in the app to code it: https://bimmercode.app/cars/f56/ These are the ones you're after though: Auto Start Stop function memorySave the last used Auto Start Stop function setting for the next start of the car.
Values: Active Not active For this option the following control unit has to be available in the car: “Body Domain Controller” BDC_01Auto Start Stop function off by defaultSet the Auto Start Stop function to off by default when the car is started.
Values: Active Not active For this option the following control unit has to be available in the car: “Body Domain Controller” BDC_01Acoustical lock/unlock confirmationEnable/disable the acoustical confirmation when the car is locked/unlocked.
Values: Active Not active For this option the following control unit has to be available in the car: “Roof Function Center” FZD__08Checkbox acoustical lock confirmationEnable/disable the checkbox in the settings for doors/keys in the iDrive system to enable/disable the acoustical lock confirmation. If the checkbox in the iDrive system does not allow selection, please check if “Acoustical lock/unlock confirmation” in the “Roof Function Center” ECU is set to “Active“ also. To make this work, the car has to be equipped with an alarm system.
Values: Active Not active For this option the following control unit has to be available in the car: “Headunit” HU_NBT or “Headunit” HU_NBT_EVO |
78007
 | Subject: Re: stop start facilty 7th October 2019, 12:46 | |
| Still waiting for my OBD connector to arrive, am I correct the bimmercode app is not free seen a couple of free downloads for computer, I had a couple of LED sidelight bulbs spare stuck them in the Mini, they work but I have a warning sidelight failure, I have looked on the app demo is there somewhere to tell the Mini the sidelights are LED seen other lamps but can't see sidelights? And one other question twice now parked up in the garage started to unpack the back and the fan kicked in it ran for a good while? |
78007
 | Subject: Re: stop start facilty 21st October 2019, 07:27 | |
| Hi got everything I need now, did the auto stop function defaulted to off, made the alarm sound when locking etc. etc. did the video but can't play anything, I put a USB with a video of wetslife in for the kids it plays the music but no picture, it's in the mp4 type of file, does the mini only play certain formats? |
78007
 | Subject: Re: stop start facilty 22nd October 2019, 07:09 | |
| Hi I asked bimmercode for support they said I may have a "this may be the basic navigation system and this is not able to play videos unfortunately". The manual says it plays video but the manual covers all models. I will have a look at mini56.com, I tried registering with a forum called mini countryman but it stated my email was not allowed? |
 | Subject: Re: stop start facilty 22nd October 2019, 18:47 | |
| Hmm strange, do you have the wider screen? If so, then I'm pretty certain you should be able to play videos. |
78007
 | Subject: Re: stop start facilty 23rd October 2019, 07:14 | |
| Yes I think the screen is wider and touch sensitive. When I used bimmercode the play video from USB was inactive, I made this active along with adding the video codes again using bimmercode, last night I tried again, but this time I selected voice command I got the message back " video playback is not currently available" but it plays the music from the MP4 video file. |
 | Subject: Re: stop start facilty 23rd October 2019, 09:45 | |
| That is strange, unless it is something to do with the format of the video. In my R56 I had a copy of The Italian Job on a USB which played, but I can't remember what format it was in. |
 | Subject: Re: stop start facilty  | |
