 Is it possible to install a sub?
Is it possible to install a sub? Vide
PostSubject: Is it possible to install a sub?   Is it possible to install a sub? Empty26th August 2009, 17:02
Hey!
I Know the stereos in r56 minis are pretty weak when it comes to bass end sounds.
I've turned the bass right up on mine(+6 in the menu) but would love to beef the sounds up abit more if possible.
A New head unit is a no no untill some aftermarket company makes one that fits into the speedo.
Just wondering if it was possible just to install a sub, and if it is, has anyone had it done??
Thanks very much!
Max
Guest
Guest
PostSubject: Re: Is it possible to install a sub?   Is it possible to install a sub? Empty26th August 2009, 21:54
noooo, do the channel swap.
http://www.totalmini.com/forum/47-2006-current-2nd-generation/5809-r56-channel-swap-boost.html
PostSubject: Re: Is it possible to install a sub?   Is it possible to install a sub? Empty26th August 2009, 22:17
Thanks Mate Thats a great idea,
didn't know you could do that!!!
Will give it a go soon!!!
PostSubject: Re: Is it possible to install a sub?   Is it possible to install a sub? Empty26th August 2009, 22:33
I've got the HiFi upgrade, it has about 240watts of power Smile
Not sure what this is over the standard version, it's loud but agree could do with a bit more bass Very Happy
PostSubject: Re: Is it possible to install a sub?   Is it possible to install a sub? Empty26th August 2009, 23:20
Sounds good!
I think i can live with the bass levels im getting with the bass tuned up to 6
but the speakers seem to be struggling!
I rekon the channel swap should sort that out with the big speakers in the back!
Guest
Guest
PostSubject: Re: Is it possible to install a sub?   Is it possible to install a sub? Empty27th August 2009, 10:12
yes it does. it's something else after the channel swap.
PostSubject: Re: Is it possible to install a sub?   Is it possible to install a sub? Empty27th August 2009, 10:33
Thanks il give that a go soon!!!
PostSubject: Re: Is it possible to install a sub?   Is it possible to install a sub? Empty27th August 2009, 18:59
hmmmm...
I gave it a go today, failed bigtime!!!
Couldn't get to the bit with all the plug thingy's (you know what u mean)
because i couldn't get the top part of trim off
any tips???
please?? lol
Guest
Guest
PostSubject: Re: Is it possible to install a sub?   Is it possible to install a sub? Empty27th August 2009, 19:53
you dont need to remove the top part of the trim at all.
take the lower part off, get to the plug - easy Very Happy
PostSubject: Re: Is it possible to install a sub?   Is it possible to install a sub? Empty27th August 2009, 20:27
haha
There we go then
Couldn't seem to reach it but il try again tommoz thanks!
What did you end up using to unplug the thingys?
I know there was some confusion on that!
Guest
Guest
PostSubject: Re: Is it possible to install a sub?   Is it possible to install a sub? Empty27th August 2009, 23:18
read my posts at the end of the MINI2 thread.
PostSubject: Re: Is it possible to install a sub?   Is it possible to install a sub? Empty27th August 2009, 23:23
okies
thanks!
