 Removng Handbrake Handle
SpykeyMyk
SpykeyMyk
Removng Handbrake Handle Vide
PostSubject: Removng Handbrake Handle   Removng Handbrake Handle Empty1st May 2010, 18:57
As Above I have a JCW Handbrake Handle to fit anyone know how to get the old one off ?
nikola
nikola
PostSubject: Re: Removng Handbrake Handle   Removng Handbrake Handle Empty1st May 2010, 19:28
Not much help, but I got BMW to do mine and it took them 2 hours! Shocked That was to remove the old one, and fit a new JCW carbon fibre handbrake handle and alcantara handbrake gaitor. I also know the JCW one has to be glued on, if that is any help! Laughing
SpykeyMyk
SpykeyMyk
PostSubject: Re: Removng Handbrake Handle   Removng Handbrake Handle Empty1st May 2010, 19:32
Yeah the Glue was in the box probably took that long because the glue had to set
PostSubject: Re: Removng Handbrake Handle   Removng Handbrake Handle Empty5th October 2010, 20:11
I am tyring to do the above on Chilli - I do can do so much but have got stuck Sad
I can remove the clip by the handbrake realese & the leather grip but no more - I tried the to prise of the other end nearest the gaitor but think the black section under the grip is stopping me. It appears i need to remove this part as i have a replacment but unsure how to remove.
Have asked for some instructions of someone else but think there for the r56
Want to see if i can do myself Razz
PostSubject: Re: Removng Handbrake Handle   Removng Handbrake Handle Empty5th October 2010, 20:19
I did a guide a while back in the DIY section, doesnt make much sence mind,
Just prise off the end, you have to force it but it will come off eventually, then the whole handle just slides off Smile
PostSubject: Re: Removng Handbrake Handle   Removng Handbrake Handle Empty5th October 2010, 20:26
As ^^ i can get the end of nearest the button & the grip, its the end nearest the gaitor/the part under the grip/leather i can remove!!!
Your diy guide if for the gaitor & not the handel isnt it Confused
Aaron
Aaron
PostSubject: Re: Removng Handbrake Handle   Removng Handbrake Handle Empty5th October 2010, 20:32
i done my gaitor and handle on sunday but hard to explain but i took my gaitor off to get the handle of because theres normally a cable tie holding it on
PostSubject: Re: Removng Handbrake Handle   Removng Handbrake Handle Empty5th October 2010, 20:38
ahhhhh i see, i get the cable tiie connection now Razz
not sure if i am brave enough to do it now Embarassed thought this would b an easy mod Sad
Well have to wait then
Aaron
Aaron
PostSubject: Re: Removng Handbrake Handle   Removng Handbrake Handle Empty5th October 2010, 20:45
its a little difficut but not to bad maye do some reaserch maybe mini 2 or something
PostSubject: Re: Removng Handbrake Handle   Removng Handbrake Handle Empty6th October 2010, 09:26
You have to take the hndle off first to get to the gaitor,
once the end part is off there is a clip that just needs to be pushed down and the whole handle will slide off
Sportspack Mark
Sportspack Mark
PostSubject: Re: Removng Handbrake Handle   Removng Handbrake Handle Empty6th October 2010, 10:21
I did it on my 1st gen one
As max says, a little brute force is needed, I have plenty of it Very Happy
All the above is correct, I just used some copydex to stick mine down
Must get around to ordering some ones for the clubman, where did you get yours from Max?
kasa
kasa
PostSubject: Re: Removng Handbrake Handle   Removng Handbrake Handle Empty6th October 2010, 11:36
I need to do the same thing, and at the moment, don't have the nerve to try and take it off (just incase I can't get the new one on!!!!). Embarassed
kasa
kasa
PostSubject: Re: Removng Handbrake Handle   Removng Handbrake Handle Empty6th October 2010, 11:38
Dawn, do you have the R56 instructions? Can I have a copy of them if you do? Thanks. Wink
PostSubject: Re: Removng Handbrake Handle   Removng Handbrake Handle Empty6th October 2010, 12:35
Not yet Hun but when/if I do I will forward them.
kasa
kasa
PostSubject: Re: Removng Handbrake Handle   Removng Handbrake Handle Empty6th October 2010, 12:50
Thank you. Kx Smile
PostSubject: Re: Removng Handbrake Handle   Removng Handbrake Handle Empty6th October 2010, 13:02
kasa wrote:
Thank you. Kx Smile
Your welcome Hug
