 Interior trim scratch help needed!
Mike
Interior trim scratch help needed! Vide
PostSubject: Re: Interior trim scratch help needed!   Interior trim scratch help needed! Empty24th June 2012, 18:54
What have you tried Emily?
A form of polish might help you and if you have a black that might work even better Smile
*Vikki*
*Vikki*
PostSubject: Re: Interior trim scratch help needed!   Interior trim scratch help needed! Empty24th June 2012, 19:04
I scratched my speedo the other day and nearly actually cried to David said try some Plastic X by meguires. Well I didn't think it would work but it got it out! I couldn't believe it, so I would give it a try on this?
PostSubject: Re: Interior trim scratch help needed!   Interior trim scratch help needed! Empty24th June 2012, 19:57
Try a normal polish first as you may be surprised Smile
I had a couple of scuffs on the mirrors and a normal polish did the trick Very Happy
*Vikki*
*Vikki*
PostSubject: Re: Interior trim scratch help needed!   Interior trim scratch help needed! Empty24th June 2012, 20:10
Hi Emily, just asked David and he said he got it from Halfords in store, they currently have 3 for two on at the moment too! He reckons it probably would as it got a similar one out of the countryman's exterior A pillar plastic.
Matt93
Matt93
PostSubject: Re: Interior trim scratch help needed!   Interior trim scratch help needed! Empty24th June 2012, 22:30
is the white from what rubbed against it?
PostSubject: Re: Interior trim scratch help needed!   Interior trim scratch help needed! Empty24th June 2012, 22:38
Just try normal polish first to save buying anything else you'll be surprised as it may come off easy.......
Matt93
Matt93
PostSubject: Re: Interior trim scratch help needed!   Interior trim scratch help needed! Empty24th June 2012, 22:39
try clay it to get the colour off...its the same for exterior as I had a yellow scratch on mine and clayed it to remove the colour - then polish?
Mike
PostSubject: Re: Interior trim scratch help needed!   Interior trim scratch help needed! Empty24th June 2012, 22:55
As Dave and I have both said use polish! Don't waste your money on Hellfrauds trim products Very Happy
PostSubject: Re: Interior trim scratch help needed!   Interior trim scratch help needed! Empty24th June 2012, 23:39
car polish Smile
give it a gentle rub!
Matt93
Matt93
PostSubject: Re: Interior trim scratch help needed!   Interior trim scratch help needed! Empty25th June 2012, 15:01
Yeah use car polish on painted plastics not non painted tho
